Hello everyone,
I have to process many IFC files from AdvanceSteel in Revit. It often happens that the geometry is displayed incorrectly.
IFC models are imported using the ggRevitUser.
Basically, I have just one question.
Can RIR components be used to identify all such parts with missing surfaces?I just want to be able to identify the base parts—nothing more.
I haven’t found any thread where this has already been discussed.
Thank you for any help or links to solutions.
unfortunately I can’t post any Revit/Rhino files. We have very strict internal security policies.
The plate, as well as the bolts and anchors, appear as “structural connections” after import.
Yes, these issues (missing surface) occur with plates that have been trimmed or bent in AdvanceSteel.
What I’m looking for is a way to identify this incorrect plates. The project I’m currently working on can have up to about 22,000 components, of which approximately 1,000 are plates.
That’s why I wanted to ask if it would be possible using RIR components.
@Willy_S Is there any parameter or code which separate the different plates?
The elements come as Directshapes so extrcating geometry back might give you some indication. This is just my as guess as we dont have any example file to work with.
you can use some sort of filtering to extract the plates and get their geometry
Find_Open_BREP.gh (7.3 KB)
P.S. I don’t know if it works inside Revit. If not, maybe you will need a custom script to do the same thing as this components.
unfortunately this component doesn’t work with “Revit elements.” Thanks anyway for the tip sometimes I have to go through Rhino, and your tip would definitely help me there.
Thanks for your reply. I’ve now connected the three plates to ElementGeometry. You can get some insight from this (see Image 1). When I connect the 3232 (see Image 2) plate to the component, GH and Revit crash. Unfortunately, that doesn’t help either.
But I’m very grateful for any ideas; until then, I’ll have to visually figure out how to deactivate the faulty plate.
@MSAwan then you have to export the geometry back to Rhino…
I use Rhino anyway to fix “mistakes.”
You might ask… why doesn’t this guy just use Rhino in the first place?
But unfortunately, that’s a little hard to explain—I’m not a “one-man show.”
