RiR - Geometry doesn't translate to Revit properly
Hello Kike,
We are trying to move into architecture domain with Rhino.Inside Revit.
Previously, simple extrusions were fine.
But once the geomery became a little more than that, the mesh starts to become broken when showing.
I cleaned up the model to check that it doesn’t have any naked edges, and tried to clean the edges as much as possible. There are parametric perforations on a few panels, and they seem to cause issues as well.
I notice this happens with any models that has more than 2 points for a straight edge ( start pt / end pt / and any extra pts that are unnecessary ).
This would be architect’s fault for modelling it in a messy way.
When I clean the model thoroughly, it comes in clean. However certain parts just won’t - even after being cleaned.
Since “clean” modelling in Rhino is not a familiar concept to most architects, would it be possible to work around this problem?
And how should I handle perforated surfaces? ( UV projected parametric patterns )
I’m not sure if I’ll be able to handle the amount of all the models they would want on Rhino.Inside Revit.
