RiR conflict with PyRevit
This might not be a Rhino related issue but I thought I’d check anyway.
I had custom settings configuration for PyRevit within my Revit environment. Once I loaded RhinoInsideRevit plugin, my settings for PyRevit have reset to default. I’m not sure how best to diagnose the issue, but I’m wondering if anyone has come across this?
I am working in
Rhino 8, 8.19.25132.01001
Revit 2025/2026
PyRevit 6.5.4.26228
Hi Diana! Still not on the latest, I see. Do note that there are a lot of changes in the latest Revits, Rhino, and RiR. Let me know if you or your IT dept need guidance on your next update cycle.
I haven’t seen anything like you are describing with pyrevit.
Here is where it’s typically stored %APPDATA%\pyRevit\pyRevit_config.ini
The config backups. pyRevit writes pyRevit_config.ini.bak-YYYYMMDD-HHMMSS when it rewrites the file.
Hey Japhy, thanks for the response!
I should totally hide behind the screen as I expose how out of date we are! Let me do some further tests as I can see a config backup but that wasn’t on the same date as when I enabled RhinoInside, so they may be unrelated.
