Rigidity calculation in Rhino/Grasshopper
I’m deigning an enclosure in Rhino, and trying to calculate its rigidity.
But I can’t find any function to input/calculate it.
Can Rhino/Grasshopper calculate such property?
If can, which grasshopper block is capable for the purpose?
Please if anyone in the community can tell me a solution, that would be great.
I can use any plug-ins if needed.
Thank you,
HN thn09
Check out the Karamba plugin. That does FEA. There’s no simple component, that I’m aware of, that you can just plugin a geometry and output a rigidity value. I think it’s a process of setting up a mesh for FEA and using the right material properties to do an analysis.
