Right mouse button to pan
Sometimes when I try to pan using the right mouse button a window instead opens up (as if I chose the OPEN command). I close the dialog and try again but the same window opens again. If I exit Rhino and restart it, I can pan. Has anyone else experienced this?
Gee
Hi Gee - does this happen with any mouse?
Hi Pascal,
I have used only one mouse. After reading your reply I tried another mouse and the problem seems to be solved.I did not know that mice makes a difference. I never had any problems with a mouse in other programs. Is this a bug in Rhino? Thanks for your help.
Gee
