Richmond Surface III
I am trying to recreate a Richmond Surface III in GH but I am having difficulty with the following:
  1. creating a single surface when using surface from points
    this is what I am getting as result
this is what it should look like
  1. I also want to keep the surface closed without gaps or overlaps when adjusting the sliders for the steps in the range component, including the v_step slider (v values) and the variable N slider.
Any help would be appreciated.
Richmond Surface.gh (10.7 KB)
I know nothing about a ‘Richmond Surface’ but came up with this white group that seems to work well, with no other changes:
Richmond Surface_2024_Jul3a.gh (21.4 KB)
Graft your A (U parameter) input for the Cross Reference, then interpolate and close-loft the points at the end?
Thank you very much to you both!
Both options work great!
