RibbonOffset bug
When I use the following closed polyline as input of RibbonOffset command, the command fails at any offset. Either it makes nothing, or it makes a monstrosity.
RibbonOffset bug.3dm (31.1 KB)
What settings are you using?
I tried almost everything. What settings are you using?
Works well here too, out of the box, adding slashes at the vertices cleans up further.
I had too big offset distance.
