Hi!
has created an import_XML.rhp that works well in Rhino 5
In new Rhino 6, I can not create Mesh from any file anymore
if I choose open file, Viewport is gone
It only works if I choose import
Hi @UtsMicke,
You have not provided enough detail for us to be of any help. Have you traced through your source code to find the problem?
– Dale
Hi!
have created a pdf with what i think is strange hope it helps
My thoughts about Rhino 6.pdf (362.9 KB)
/ Michael
Is this a plug-in that you or a third-party wrote? Or are you trying to open a DWG file with Rhino without using any non-Rhino plug-in?
just RHINO own plug-in
Could you please paste the contents of the window that pops up when you run in Rhino the command _SystemInfo
Rhino 6 SR1 2018-2-6 (Rhino 6, 6.1.18037.13441, Git hash:master @ 5a33e6871b94d32ba552468218cef0ad8d3d1263)
Windows 7 SP1 (Physical RAM: 24Gb)
Quadro 2000/PCIe/SSE2 (OpenGL ver:4.4.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.4
Shading Language: 4.40 NVIDIA via Cg compiler
Driver Date: 8-4-2014
Driver Version: 9.18.13.4066
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\Tutorials.rhp “Tutorials”
C:\Program Files\Rhino 6\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
Could you please update your GPU driver to the most recent? A search on NVidia drivers page yields Quadro Desktop/Quadro Notebook Driver Release 375 | R375 U11 (377.83) | Windows 7 64-bit, Windows 8.1 64-bit, Windows 8 64-bit | NVIDIA
Let us know if that helps with the black viewport issue.
Thanks,
/Nathan
Quadro 2000 340.66 Your PC currently has the latest driver installed for your GPU. No driver update is necessary at this time.
From what you are describing, this doesn’t look like a display bug. It looks like something is going wrong while importing or opening a dwg file. Do you have a sample dwg file that we can test with?
if I import dwg, it’s no problem, the problem is only when I choose open dwg
AKL - VA Rit MS60b.zip (1.3 MB)
and I also have my own plug-in that works if I import but not if I choose open
Hi @UtsMicke,
Thanks, I’ve reported this bug.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44223
– Dale
Thanks. now i can work with dwg
but I have a similar problem
has created a plug-in that creates a new layer and a mesh
When I import the file, the layer and mesh are created
but if I open the file there is nothing
send with vb.net code and test file
code and file.zip (248.6 KB)
/Michael
Hi @UtsMicke,
Your plug-in’s ReadFile
member needs to return either True
or False
Protected Overrides Function ReadFile(filename As String, index As Integer, doc As RhinoDoc, options As Rhino.FileIO.FileReadOptions) As Boolean
Dim rc = False
If (File.Exists(filename)) Then
Dim layerName = Path.GetFileName(filename)
Dim layerIndex = doc.Layers.Add(layerName, System.Drawing.Color.Black)
If layerIndex >= 0 Then
doc.Layers.SetCurrentLayerIndex(layerIndex, True)
End If
Dim mesh As New Rhino.Geometry.Mesh()
mesh.Vertices.Add(0.0, 0.0, 1.0)
mesh.Vertices.Add(1.0, 0.0, 1.0)
mesh.Vertices.Add(2.0, 0.0, 1.0)
mesh.Vertices.Add(3.0, 0.0, 0.0)
mesh.Vertices.Add(0.0, 1.0, 1.0)
mesh.Vertices.Add(1.0, 1.0, 2.0)
mesh.Vertices.Add(2.0, 1.0, 1.0)
mesh.Vertices.Add(3.0, 1.0, 0.0)
mesh.Vertices.Add(0.0, 2.0, 1.0)
mesh.Vertices.Add(1.0, 2.0, 1.0)
mesh.Vertices.Add(2.0, 2.0, 1.0)
mesh.Vertices.Add(3.0, 2.0, 1.0)
mesh.Faces.AddFace(0, 1, 5, 4)
mesh.Faces.AddFace(1, 2, 6, 5)
mesh.Faces.AddFace(2, 3, 7, 6)
mesh.Faces.AddFace(4, 5, 9, 8)
mesh.Faces.AddFace(5, 6, 10, 9)
mesh.Faces.AddFace(6, 7, 11, 10)
mesh.Normals.ComputeNormals()
mesh.Compact()
if mesh.IsValid() Then
doc.Objects.AddMesh(mesh)
End If
rc = True
End If
Return rc
End Function
– Dale
