Hi there! I’m experiencing very unplesantly slow performance in anything I do in Rhinoceros 64bit version. For example even window resizing and typing in the command line as well as maximizing one of the viewports, simply everything! It looks like each single operation takes about 10 seconds, which is unbearable. Other running programs are behaving normally. The strange thing is that in Rhinoceros 32bit none of this happens.
I already reinstalled Rhino and the problem didn’t disappear.
Any suggestions?
CPU: i5-3320M
RAM: 16GB
SSD: Samsung 850 EVO 500 GB
OS: Windows 10 Pro
Version: 1607
OS Build: 14393.1198
Lastly, have you tried the WIP version of Rhino-6? Click the link which is above the forum to get it. See if you have the same problem there (they can be installed side-by-side).
I’ll have to check for the updates, I’m not at the machine right now. Rhino 6 WIP us running fine, it’s just the x64 Rhino 5 version.
One more strange thing us that this behavior isn’t persistent, sometimes after a restart the x64 version works fine, other times restart doesn’t solve anything…
