I would like to use a RhinoViewport object in a dialog for custom drawing purposes
but I see there is no SetScreenPort to set the size in pixels
Is there anyway to overcome this ?
thanks
gerry
thanks
gerry
var views = Rhino.RhinoDoc.ActiveDoc.Views;
if (views.Find("ViewName", true) == null)
int viewWidth = 300;
int viewHeight = 300;
views.Add(viewName, DefinedViewportProjection.Perspective, new System.Drawing.Rectangle(0, 0, viewWidth, viewHeight), true);
var view = views.Find("ViewName", true);
Run above C# stript to create a viewport with custom size 300 * 300.
Thanks, not really what I was searching for but useful
gerry
Hi @gerryark,
You might have a look at Rhino.UI.Controls.ViewportControl
. Here is a Python sample:
I probably have a C# sample hiding somewhere, if needed.
– Dale
This seems what i need
I can do a port to c#
Thanks
Gerry
Could you share the C# port? thanks
