I tried to find a bit of information about how to generate Sweep2 and didnt really solve the problem. I know it is a bit of a hassle working with Argument classes and that everything has to fit perfectly, but I hope you will be able to tell me why my Sweep2 Function doesn`t work, and if there is a quick fix…thanks!
bool Sweep2( ON_Curve* rail1, ON_Curve* rail2, ON_SimpleArray<ON_Curve*> sectioncrvs, ON_SimpleArray<ON_Brep*> brep_arr)
CArgsRhinoSweep2 args;
int i,j;
CRhinoPolyEdge edge1,edge2;
edge1.Create( rail1 );
edge2.Create( rail2 );
args.m_rail_curves[0] = &edge1;
args.m_rail_curves[1] = &edge2;
for( i = 0; i < sectioncrvs.Count(); i++ )
args.m_shape_curves.Append( const_cast<ON_Curve*>(sectioncrvs[i]));
//find the parameters
ON_3dPointArray respts1, respts2;
IntersectCurveCurve(sectioncrvs[i], rail1, respts1); //THIS IS MY FUNCTION THAT WORKS PROPERLY - I CHECKED
IntersectCurveCurve(sectioncrvs[i], rail2, respts2); //THIS IS MY FUNCTION THAT WORKS PROPERLY - I CHECKED
if(respts1.Count() >0 )
double t;
sectioncrvs[i]->GetClosestPoint( respts1[0], &t );
args.m_rail_params[0].Append( t );
if(respts2.Count() >0 )
double t;
sectioncrvs[i]->GetClosestPoint( respts2[0], &t );
args.m_rail_params[1].Append( t );
args.m_bClosed = false;
args.m_bSimpleSweep = true;
args.m_simplify = 0; // Simplify method for shape curves
args.m_rebuild_count = -1; // Sample point count for rebuilding shapes
args.m_refit_tolerance = 0.01;
args.m_sweep_tolerance =0.01;
args.m_angle_tolerance =0.01;// RhinoApp().ActiveDoc()->AngleToleranceRadians();
RhinoSweep2(args, brep_arr );
return true;
I will try it out and let you know. Can you tell me what the start_pt and end_pt represent in this function? They confused me from the start when I saw them in the argument list…
If I select the two rails left and right and the line bellow as the cross section…I get to select one “end point”…this is the result: (I tried changing the code to select two points above , start_pt and end_pt, but then nothing gets generated)
Sweep2 allows for optional starting and end point as cross sections (for lack of better term). See the Sweep2 command help for details. Note, these points are not required…
Thanks. It did work at the end. The end points should be avoided (if you do not specifically want to have a point instead of a cross section) and you have to check your directions…for example rail curves have to have the same orientation apparently…
Hi all,
I am having the same problem but I cannot find a way to get the sweep 2 in my plug-in. The example simply gives me nothing, while with the same curves the command Sweep2 in Rhino generates the surface I need.
If I use the end point I have the same @dimcic got in his picture. By the way I really need to sweep curved curves and defining the curve with points does not seem to be a suitable option.
Anybody has a suggestion?
Thanks!!
