@stevebaer I suppose:
I just found that a python set
object is not accepted as itterable in rhinoscriptsyntax.BoundingBox
geometry.py starting at line 343:
bbox = Rhino.Geometry.BoundingBox.Empty
if type(objects) is list or type(objects) is tuple:
for object in objects:
objectbbox = __objectbbox(object, xform)
bbox = Rhino.Geometry.BoundingBox.Union(bbox,objectbbox)
else:
objectbbox = __objectbbox(objects, xform)
as utility.py coerceguidlist does successfully coerces a list from a set this could better read:
utility.py coerceguidlist does not handle sets , I think it would be a valuable addition to also accept sets and use it at BoundingBox like below
objectlist = rhutil.coerceguidlist(objects)
if not objectlist: return scriptcontext.errorhandler()
for object in objectlist:
P.S. @stevebaer I now see the use of object
as variable all over the modules yet that is a buildin python type…
-Willem
