I built a plugin based on voice recognition.
For a reasons that i ignore.
If I use RhinoApp.RunScript
for starting a new command, I can not execute a second command with ‘RunScript’ or ‘SendKeystrokes’ (like ! _Box
or just !
for cancel if I say “Cancel”).
If I use RhinoApp.SendKeystrokes
for starting a new command, I can run the second command but SendKeystrokes
unselect all object before send the string.
All tests without the speech recognizer work exept SendKeystrokes
that are invariant (it unselect all object before send the string).
I assume that RunScript
creates a new thread and not SendKeystrokes
. I have good ?
To clarify the reaction between RunScript
and SendKeystrokes
in my plugin :
I say | RhinoApp | Then I say | RhinoApp | result | |
“Union boolean” | RunScript("! _BooleanUnion", true) |
“Cancel” | RunScript("!", true) |
not work | |
“Cancel” | SendKeystrokes("!", true) |
not work | |
“Union boolean” | SendKeystrokes("! _BooleanUnion", true) |
Unselect all previous objects | “Cancel” | RunScript("!", true) |
work |
Unselect all previous objects | “Cancel” | SendKeystrokes("!", true) |
work |
Have an idea why it works like this?
How can I prevent SendKeystrokes
from deselecting all objects before sending the string?
Thank you,
jmv
(note: of course, I placed a RhinoApp.Wait
before executing a command)
