I am trying to write a Rhinoscipt program to run from the Windows command prompt that closes Rhino when it is complete. At the end of my code, I have been successfully using Rhino.Exit; however, it doesn’t work when I try to use it to abort the script in case of an error.
The script below attempts to create geometry using a parameter-driven Grasshopper file. It then checks if any geometry exists, writing the current state to a flag and exiting if necessary. I have tested the code and found that the flag is correctly written as “0” if there is no geometry; but then why doesn’t Rhino.Exit run?
Any help would be greatly appreciated.
Thanks,
Josh
Call Main()
Sub Main()
' Auto-bake a Grasshopper file that can fail to generate geometry under certain conditions
' (This is not an issue with the file and cannot always be determined in advance)
' Check that geometry was created
Dim objects
objects = Rhino.AllObjects(False,True)
' Get the file system object
Dim objFSO, objStream
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Open a text file to write to
Set objStream = objFSO.CreateTextFile("GHflag.txt", True)
If Err Then
MsgBox Err.Description
Exit Sub
End If
' Print flag file
If IsArray(objects) Then ' Print Success
objStream.WriteLine("1")
Else ' Print Fail
objStream.WriteLine("0")
Rhino.DocumentModified(False)
Rhino.Exit
End If
' Close the file
objStream.Close
Set objStream = Nothing
Set objFSO = Nothing
' Do other stuff
' Exit Rhino
Rhino.Exit
End Sub
