Hi !
has created a number of RhioScript packages that I packed with Monkey Script Compiler
and it has worked in Rhino 5 but now it’s stop or ?
Help!
Hi !
Help!
Hello - we’ll need a bit more detail - for example, have you run the individual scripts, and do they all work? Are they compiled using an SDK that is compatible (i.e. same or earlier SR than the Rhino you are testing) ?
Hey!
I think I solved the problem with RhioScript packages, I’ve packed the code with RhinoScriptCompiler and the menu I create in Rhino as the Toolbar
