Rhinoscript creates 5 default layers, how to disable?
Dear community,
Just a short question: whenever I run my Rhinoscript, default layer 01 to 05 are created, next to the layers I add myself. Can I disable that these 5 default layers are added?
Many thanks in advance,
Kind regards,
Filip Rooms
Can you post the code?
In your script, are you opening a new file or importing a file that has these layers already?
–Mitch
You could simply add some code to delete the 5 layers, assuming they are empty.
Are you sure these layers not not in Rhino’s default template file? (Tools → Options → Files)
They indeed originated from my template… I remove them in an initializer function, as suggested by BrianM.
Thanks for the suggestions…
Kind regards,
Filip
