Rhinoscript addleader not undoing
I’ve got a script that generates a bunch of dimensions and leaders. I’ve noticed that after running the script, if I select the leader objects and change their style assignment, that if I then try to Undo the script, the adding of the leader objects doesn’t undo, they stick around. The rest of the geometry goes away correctly.
Hi Jim,
Rhino 5? Can you post a simple sample, along with step-by-step instructions, that repeats the problem.
– Dale
