Hi everyone
There is any possible way to plugin .rhp file into rhino using rhino C#
Any option to install .rhp file in rhino c#
-Sarath
Hi everyone
-Sarath
Changed to Developer category
Hi @Sarath_Kithiyon,
RhinoCommon for Rhino 5 does not have a function to install a plug-in.
RhinoCommon for the Rhino WIP does - just use the PlugIn.LoadPlugIn
override that accepts a path string parameter.
Does this help?
– Dale
The only way I can think of via Rhino 5 would be to use RunScript passing -Options _Plugins _Load and then passing the filename string.
Hi @dale
Thanks,
PlugIn.LoadPlugIn is load previously pluged .rhp files only it not working for new Plugin .rhp file
-Sarath
Yes, Rhino 5’s compatible RhinoCommon Plugin.LoadPlugIn will only accept a GUID of an already registered plug-in. The RhinoCommon for Rhino 6 WIP has a new overload for this method that will now also accept a string path to load a plug-in from disk.
For Rhino 5 a RunScript command would be about the only alternative as I mentioned in the post above.
-Trav
