RhinoPipe C++
I would like to use the RhinoPipe function to make extrusions from some curves. In one version it is a joined curve consisting of multiple ON_ArcCurve and ON_LineCurve. In a second version, I try to create pipes for each curve separately.
The question is how do I get an ON_Brep (which is my final goal in all cases) from ON_SimpleArray<ON_Object*> results ?
Thanks!
Milos
Hi Milos,
See if this helps:
https://github.com/mcneel/Rhino5Samples_CPP/blob/master/SampleCommands/cmdSamplePipe.cpp
– Dale
