RhinoLands 6.6 released
Hi all,
While we keep developing RhinoLands 7 with many improvements and new features, and preparing version 6 to support Rhino 9, that’s coming soon, we haven’t forgotten about you!
RhinoLands/Lands Design 6.6 is already available for download.
This minor update fixes some errors, crashes and freezes we detected last months. Here is the What’s new list:
Improvements:
  • Plant Photo and Label’s leader head and curve are now flat, so that the whole object is 2D (contained in a plane). This way user can elevate it to easily control the z-ordering in respect to other 2D objects on the Planting plan.
Error fixes:
  • Level Mark not elevated to Terrain during insert, on AutoCAD.
  • In laWalk command, in Fly mode, when view direction was parallel to Z axis (for example, when starting from a Top view), moving to left/right was applied to the screen vertical axis.
  • Ramp not elevated to terrain.
  • laShrub command asked for a “path” curve when requiring a “boundary” curve.
  • Per-square-meter Shrub didn’t work with non-planar closed curves.
  • la2D and la3D commands had no effect on Row objects.
  • Osnaps didn’t work on Urban Furniture blocks.
  • Image previews not displayed when Cloud Images were enabled in Plant Database.
  • Wall objects not rendered in nXtRender.
  • Terrain division area could be 0 if division curve was not planar.
  • Lands commands didn’t show any content on Help Panel.
  • After exploding a Lands object, some entities had layer set to “By Parent”.
Crash/freeze fixes:
  • Crash in Lists ordered by the icon field.
  • Crash in Lists with no icon field, like Terrain List.
  • Crash when a Plant Species was inserted into a document with Lands settings from a newer Lands version.
  • AutoCAD crash when zoning an existing Terrain division.
  • AutoCAD freeze after selecting objects, sometimes.
Notes
  • Supported Rhino versions:
    • Rhino 8 SR28 or later, and
    • Rhino 7 SR33 or later
  • Supported AutoCAD versions:
    • AutoCAD 2027, 2026, 2025, 2024, 2023, 2022 and 2021
Enjoy it!
