Hi
I don’t know how it happened, but I lost the Rhino Inside Settings button.
I tried uninstalling and reinstalling RIR, but that didn’t solve the problem.
It seems to be remembering my user settings even after reinstalling, so I suspect that’s the issue.
Could you give me a hint on how to reset those settings?
Thanks!
Japhy
(Japhy)
February 6, 2025, 3:36pm
2
That’s odd, not seeing a way to remove it. I’ll keep poking
In the meantime you can create a Revit shortcut to the Options
I had the same idea for a quick fix but couldn’t find it in the shortcuts.
This works for now—thanks!
I initially thought it was due to having too many of those buttons , but that doesn’t seem to be the issue.
It would be great if there were a way to reload the toolbar without restarting Revit. In PyRevit, you can…
Japhy
(Japhy)
February 6, 2025, 3:52pm
4
What are your setting in the General Tab of the Rhino.Inside.Revit options dialog?
Japhy
(Japhy)
February 6, 2025, 4:00pm
6
I was able to repeat with these checked (after restarting revit), unchecking and restarting Revit will get the Options back.
I changed it to not Start Rhino on startup and the options came back after restarting revit.
I just have a follow-up question regarding shortcut assignments.
Would it be possible to assign shortcuts to scripts in the toolbar?
For custom scripts in PyRevit, this is possible.
Would be great to have it in Rhino.Inside as well.
