We’ve updated the repo with a new sample, now we have previews in the Revit view.
If you load Rhino inside Revit and run the “Sample 6” command, you can found it on the Add-Ins tab, your Rhino geometry will be previewed in the Revit view over the model, per object and per layer visibilty is respected.
We also have same functionality with temporary geometry on Grasshopper, it’s also shown on the Revit view using the normal and selected color Grasshopper uses. It also honors the preview selected and preview disabled states you can enable from the Grasshopper toolbar.
If someone is curious and wants to try, you can found it here
Please tell us if you found anything annoying or unexpected that needs to be changed or fixed.
