Dear all,
I create geometries from a GH definition and then I transfer architectural elements into Revit.
But after closing my file, if the day after I try to open again the file (Revit > Rhino > Gh) with the same definition, when opening GH I get this breakpoint: Grasshopper has failed to deserielize some data of type Rhinoinside.Revit.GH.Types.HostObjectType.
It is as if the “type” reference is lost.
Maybe I have to reference the file somehow?
There is a quick fix on version 0.8, do you mind testing it?
To install it you should change the update channel to ‘Daily’ from the Rhino.Inside Options dialog.
