“RhinoInside.Revit.Convert.ConversionException”
Curve is too short for Revit’s tolerance. Length should be greater than short-curve tolerance
When trying to import Rhino geometry into Revit. Any ideas on how to resolve? Note that the Rhino file does not contain any 2D curve elements - just open surfaces.
Unrelated but it’s still not possible to toggle between Rhino and Revit once the plug-in is loaded. Revit will immediately crash if I switch to any other active program with the Rhino.Inside plug-in loaded.
