I get a linker error trying to compile RHINO_SDK_FUNCTION RhinoGetRevolve.
CArgsRhinoRevolve args;
ON_SimpleArray<ON_RevSurface*> srfs_out;
RhinoGetRevolve(args, srfs_out);
Is this function still being exported for usage in the SDK?
Thanks
Thanks
Hi @Gary,
It looks like RhinoGetRevolve
is declared but not implemented. Do you need the interactive revolve user interface? Or are you just looking just to create a surface by revolving a profile curve around an axis. Because if it’s just the latter you can just use the RhinoRevolve
function. See rhinoSdkGetRevolve.h for details.
– Dale
I need the interactive user interface, so I will just cook one up myself then use the RhinoRevolve function.
Thanks Dale.
