hi why does RhinoDocument.Objects.AddBrep(tmp);
in visual Studio unknow?
And
Guid id = Rhino.DocObjects.Tables.ObjectTable.AddBrep(tmp); ```have errors ! too
but i found solution
Guid guid = Rhino.RhinoDoc.ActiveDoc.Objects.AddBrep(brep);
Your first error happens because there is no class called RhinoDocument
. There is RhinoDoc
though.
Then your second error is because AddBrep
is an instance method, so you need to call it on an instance of ObjectTable
. As you found out the Objects
property on a RhinoDoc
instance will let you call the AddBrep
method.
