RhinoDoc.SelectObjects + filter
I have assigned my own event to the RhinoDoc.SelectObjects, however it doesn;t run when selecting objects with use of filter, for example when I run command “Select surfaces” this event RhinoDoc.SelectObjects doesn’t run. Is there any other event I need to overwrite? I use C#
I guess I don’t understand the problem and will need more explanation or sample code.
This sample seems to do what you say isn’t happening:
https://github.com/dalefugier/SampleCsEventWatcher
But again, I’m not sure what you are describing…
