RhinoDoc.Export to STEP leads to error
Hi all,
I have tried to save geometry data in STEP format using “RhinoDoc.Export”. This leads to the following error:
export_STEP.rhp load error: Global CRhinoPlugIn object plug-in type is incorrect.
The error occurs also with other formats. Only with the 3DM format it does not occur.
Rhino 7 is installed as a trial version. Rhino Inside was loaded as NuGet package in Visual Studio 2022.
What can I do to save files in STEP format?
Thanks a lot
Thomas
Hi all,
Bought an upgrade license today.
“RhinoDoc.Export” now works as expected.
Now exporting files in STEP format is no longer a problem.
An expired Rhino evaluation caused the problem.
Thomas
