Hello All,
I am interested in learning rhinocompute and was following Junricho Horikawa’s youtube tutorial. However, these are some of the issues which I encounter. Below is the sample code. Auth token is
not mentioned here. I am using PyCharm IDE and Decode property has some issue
CODE>>>>
import rhino3dm
import random
import compute_rhino3d
import compute_rhino3d.Util
import compute_rhino3d.Curve
model = rhino3dm.File3dm()
compute_rhino3d.Util.authToken = “-----”
curves =
for i in range(20):
pt = rhino3dm.Point3d(random.uniform(-10,10),random.randint(-10,10),0)
circle = rhino3dm.Circle(pt,random.uniform(1,4))
curve = circle.ToNurbsCurve()
curves.append(curve)
bcurves = compute_rhino3d.Curve.CreateBooleanUnion(curves)
for bcurve in bcurves:
bcurveObj = rhino3dm.CommonObject.Decode(bcurve)
model.Objects.AddCurve(bcurveObj)
model.Write(‘boolean2d.3dm’,6)
Error on PyCharm IDE >>>
line 39, in
TypeError: Decode(): incompatible function arguments. The following argument types are supported:
1. (jsonObject: dict) -> rhino3dm._rhino3dm.CommonObject
Invoked with: <rhino3dm._rhino3dm.NurbsCurve object at 0x000001E485F80CB0>
