Hello Rhino.Compute team. The RhinoCompute.cs source (from https://compute.rhino3d.com/sdk/csharp) seems to have missing definition for the enum type SetsCombinations. Commenting out the two methods that depends on this type (IntersectionCompute.MeshMesh and its overloaded version) allows the file to compile as usual.
Thanks, I just updated the C# file which can be found at
This will also be available from compute.rhino3d.com/sdk/csharp once we update that server.
Hi Steve, did you simply remove the MeshMesh methods triggering that error? Because in the linked file they are still included, on the github they aren’t,
Also, none of the links here work: https://developer.rhino3d.com/guides/rhinocommon/compute/compute-getting-started/
The links should be fixed now, thanks
