I’m trying to think of a method how to identify if a certain surface is an ellipsoid. I only find a test to identify a sphere.
Complication: the ellipsoid does not need to have its axes aligned with the world axes.
1: find singularities ( at surface domain extremes ) and construct axis-line inbetween
2: section with plane perpendicular at mid-point axis-line
3: test if section is circular (enough), sample additional points on axis-line and test perpendicular sections for circularity
any of these tests in addition:
get the edge (or intersections with planes through axis-line) , and scale 1D along to section line to test for circularity
compare theorectical ellipsiod volume with surface volume(area)
All of this assumes an ellipsiod spanning at least from singularity to singularity yet for trimmed parts I have nothing shoot.
If the isocurves do not correspondent with the triaxial deformation then you need to find the minimum boundingbox and create the section curves based on that box (see attached ). Ellipsoid.3dm (131.4 KB)
I also don’t know what the bug-fix is about but I found that the IsEllipse check is pretty tolerant. However, once you have the minimum bounding box you can scale the sections to be quadratic and check if these are circles.
The tricky part is to find the minimum boundingbox. I made something for that
but it is not ready to be released.
I made the item public. There was a bug in the way RhinoCommon was passing the IsEllipse() test to the C++ SDK. It resulted in false negative results in the test. This is fixed in Rhino WIP.
