Rhinocommon PointContainment
I have a problem with the type PointConaintment
I have the value outside from this code. What can I do with that?
I do not get a 0,1,2, or 3 from it.
I thank you for your response : )
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_PointContainment.htm
If I remember correctly, you have to compare your result to for instance Rhino.Geometry.PointContainment.Inside to check whether it is contained or not. The same goes for the three other possible results.
