Thanks Nathan
Regarding the Preview issue - this is definitely not working right. I can update an Octane Material (which saves to the RenderMaterial Fields) and then click Update All Previews, and CreatePreview(CreatePreviewEventArgs args) is not called. And them occassionally it is! So Rhino does not seem to be setting the “is dirty” flag on the material when my plugin sets the Field data.
Also, my Rhino5 code is
protected override void CreatePreview(CreatePreviewEventArgs args)
if (!(args.PreviewContent is OctaneRenderMaterial))
return;
in order to filter out non-Octane material previews. I was told to change this to the following for RhinoWIP:
if (args.ContentTypeId != this.Id)
return;
…which was working for previous RhinoWIP builds - however with the current build the “this.id” is different from the “args.ContentTypeId” being passed to CreatePreview (so therefore the Preview is not being done).
It looks like CreatePreview is being passed with the assembly GUID rather than the PhysicalcSoftware.OctaneRender.RhinoPlugin GUID.
Paul
