Not sure if this is highlighted anywhere already.
Any hint how to do it?
Small example would be highly appreciated.
Thanks,
Dmitriy
Thanks,
Dmitriy
Hi @Dmitriy,
Make a script runner command, and then call RhinoApp().RunScript("_-Import ...")
– Dale
Thanks, Dale
If you want to process the objects before they are added to the doc then the File3dm
class may be of interest as well.
http://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_FileIO_File3dm.htm
