Rhinocommon function to get duplicate curves
Yes, you are absolutely correct. Thanks for pointing it out.
It is not possible to use tolerance the way I did, some points will be “rounded” to different values even if they are very close to each other (=> distance less than tolerance).
So I updated code to do the job but WITHOUT TOLERANCE. I tested it on few millions different curves and it seems to give the same result as SelDupAll command in Rhino. And it is very fast at the same time.
Here is the code:
    public delegate uint CreateCurveHashCodeDelegate(NurbsCurve crv, int salt);
    public struct HashIndexPair
        public uint Hash { get; set; }
        public int Id { get; set; }
        public HashIndexPair(uint hashPrm, int idPrm)
            Hash = hashPrm;
            Id = idPrm;
    public static List<bool> FindDuplicteCurvesA(List<Curve> curves)
        //Reverse curve direction where necesary
        var curvesToCheck = curves.Where(x => x != null)
                                    .Select(x => {
                                        if (x.PointAtStart > x.PointAtEnd) x.Reverse();
                                        return x;
                                    }).ToList();
        var nurbsCurves = curvesToCheck.Select(x => x.ToNurbsCurve()).Where(x => x != null).ToList();
        if (curves.Count != nurbsCurves.Count)
            RhinoApp.WriteLine("*** FAILED TO CONVERT TO NURBS CURVES.  CurvesCount={0},  NurbesCurveCount={1}", curves.Count, nurbsCurves);
            return new List<bool>();
        if (nurbsCurves.Count < 2)
        //Now we group curves in groups based on the same hash-code retrun by our hasing method; for grouping we use ILookup
        CreateCurveHashCodeDelegate createMyCurveHashCode1 = CreateCurveHashCodeX3;
        var curvesLookupStart = nurbsCurves.Select((x, i) => new HashIndexPair(createMyCurveHashCode1(x, 101), i)).ToLookup(y => y.Hash, y => y.Id);
        var curvesLookUpShrinked = ShrinkLookup(curvesLookupStart, nurbsCurves, 313, createMyCurveHashCode1);
        bool[] DuplicateStatus = new bool[curves.Count];
        foreach (var group in curvesLookUpShrinked)
            var ids = group.Select(x => x).ToList();
            for (int j = 0; j < ids.Count; j++)
                DuplicateStatus[ids[j]] = true;
        return DuplicateStatus.ToList();
    public static ILookup<uint, int> ShrinkLookup(ILookup<uint, int> lookUpToShrink, List<NurbsCurve> curves, int salt,
                                    CreateCurveHashCodeDelegate createMyCurveHashCodeDelegate)
        List<IGrouping<uint, int>> result = new List<IGrouping<uint, int>>();
        foreach (var group in lookUpToShrink)
            int grpCount = group.Count();
            if (grpCount == 1)
                // skip single-item group => group has one item that has no duplicates
                continue;
            var groupLookUp = group.Select(x => new HashIndexPair(createMyCurveHashCodeDelegate(curves[x], salt), x))
            if (groupLookUp.Count > 1)
                //group has been divided into more subgroups by using actual hashing-method => try to shrink subgroups more
                var shrinkMore = ShrinkLookup(groupLookUp, curves, salt * 2 + 1, createMyCurveHashCodeDelegate);
                result.AddRange(shrinkMore);
            else
                result.AddRange(groupLookUp);
        var resultLookup = result.SelectMany(x => x.Select(y => new HashIndexPair(x.Key, y))).ToLookup(x => x.Hash, x => x.Id);
        return resultLookup;
    public static uint CreateCurveHashCodeX3(NurbsCurve crv, int salt)
        int myHash = 0;
        unchecked
            for (int i = 0; i < crv.Knots.Count; i++)
                myHash ^= crv.Knots[i].GetHashCode() * (2 * i + salt);
            for (int i = 0; i < crv.Points.Count; i++)
                myHash ^= saltHash(crv.Points[i].Location.GetHashCode(), salt) * (31 * i + 1);
                myHash ^= saltHash(crv.Points[i].Weight.GetHashCode(), salt) * (97 * i + 1);
            myHash ^= crv.Degree * 1559;
            myHash ^= crv.Dimension * 2029;
            myHash ^= saltHash(crv.Domain.GetHashCode(), salt) * 1699;
            myHash ^= saltHash(crv.IsClosed.GetHashCode(), salt) * 4099;
            myHash ^= saltHash(crv.IsPeriodic.GetHashCode(), salt) * 4447;
            myHash ^= saltHash(crv.IsValid.GetHashCode(), salt) * 5557;
            myHash ^= crv.SpanCount * 9199;
        return (uint)myHash;
    public static int saltHash(int hash, int divisor)
        int remainder;
        Math.DivRem(hash, divisor, out remainder);
        return hash + remainder;
Addendum: to be 100% sure that curves are equal probably EsilonEqual check on resulting list should be processed because still two different curves can return the same hash-code value.
Hi @RadovanG,
Really impressive piece of code, it works like a charm.
Quick question : why do you use a salt into your hashing function? I thought that salt hash had to do with security concerns, I guess your are not really worried about your sel dup function being hacked :smiley:
Cheers
–Xavier
Hi Xavier
Here is updated code for FindDuplicteCurvesA() method which at the end implements EsilonEqual comparison for ceases when two different curves returns the same hash-code value.
                                    .Select(x => {
                                        return x;
                                    }).ToList();
            for (int i = 0; i < ids.Count-1; i++)
                for (int j = i + 1; j < ids.Count; j++)
                    if (!DuplicateStatus[ids[i]] || !DuplicateStatus[ids[j]])
                        if (nurbsCurves[ids[i]].EpsilonEquals(nurbsCurves[ids[j]], RhinoMath.ZeroTolerance))
                            DuplicateStatus[ids[i]] = true;
Regarding saltHash function it is there to try to minimize appearance of same hash values for series of different input values. It does not have to be there, you can use hash-values without salting it.
But what you have to do is to multiply hash with some constant int before you XOR it with next hash value for next property. For example, if you have two sets of three numbers {a1, b, b} and {a1, d, d} and b != d, then (a1^b)^b will give you a1 and (a1^d)^d will give you also a1 !!
Radovan
