Hello!
Wondering which is the appropriate* method for adding export options to an Export Plugin in rhinocommon? For example, I’d like the SaveFileDialog to show options in a similar manner to some of the other exporters:
When the user hits ‘save,’ the options page should appears with the custom exporter options. I can write a form that will prepare these options for me, but it seems there is some built in functionality to the PlugIn Class and OptionsDialogPages stands out as something I should override, but an example would be great.
*when I say appropriate, I mean an option that would be compatible across platforms
It seems heavily dependent on System.Windows.Forms and other things that might not work well on other platforms. Perhaps I try the ETO route and just run a control when the user gets to the appropriate part of the code.
For the couple of I/O plugins that I’ve ported over from C++ to C# and RhinoCommon, having the test command that included the file extension in the name worked for me. Here’s an example from the PLY export plugin.
[CommandStyle(Style.Hidden | Style.Transparent)]
public class ExportPlyPlugInOptionsCommand : Rhino.Commands.Command
public override string EnglishName
get { return "PLYExportOptionsDialog"; }
return ExportPlyPlugIn.Instance.UI(true, true);
