RhinoCommon equivalent of DivideAlongCreases/SplitAtTangents?
How can one create a SplitAtTangents equivalent as a post-process to the various Brep creation methods like Sweep? I don’t see any exposed method for this…
Thanks, --Mitch
These methods don’t exist in RC5:
http://developer.rhino3d.com/wip/api/RhinoCommonWin/html/M_Rhino_Geometry_Collections_BrepFaceList_SplitFaceAtTangents.htm
http://developer.rhino3d.com/wip/api/RhinoCommonWin/html/M_Rhino_Geometry_Collections_BrepFaceList_SplitFacesAtTangents.htm
OK, should have checked that first, thanks… Too bad it’s not available in V5. --Mitch
I think they are in Rhino 5, see http://developer.rhino3d.com/api/RhinoCommonWin/html/M_Rhino_Geometry_Collections_BrepFaceList_SplitKinkyFaces.htm
It says rhino 5 at the top of the page, and I seem recall using this function in Rhino 5.
Hmm, but does it also split at tangent (G1) joints as well as kinks? --Mitch
Oops, there I go again, only half reading… Probably not. Sorry :blush:
The you might be able to do in Rhino 5 is to set the splitKinkySurfaces flag when calling doc.AddBrep.
Hi Dale - doesn’t seem to work to split faces at tangent joints… --Mitch
Hi Mitch,
Sorry, I didn’t read your post close enough.
In V5, your best best is to script the DivideAlongCreases command, using SplitAtTangents=Yes. In V6, there is a RhinoCommon method for this (referenced above).
– Dale
Yep, that’s what I finally ended up doing… Thanks Dale. --Mitch
