Rhinocommon DisplayMode Change Event
I would like to know if there is a way to detect if any viewport changes its display mode to raytraced, in order to change some object materials, Anyone know if that is posible?
Thanks in advance.
Will
Hi @Harper,
If you are developing in C++, you can create a CRhinoDisplayModeChanged event watcher. This is not yet available in RhinoCommon, however.
Does this help?
– Dale
Hi @dale Thanks for the answer, I’m using rhinicommon C#, is there a way to make a wrapper from rhinocommon_c?
Hi @Harper,
I’ve added your request to the pile.
https://mcneel.myjetbrains.com/youtrack/issue/RH-52991
– Dale
Thank you.
RH-52991 is fixed in the latest Service Release Candidate
Thanks!
Will.
