RhinoCommon C# Recognize ObjectType
this is a pretty basic question, but what would be the easiest option to recognize the ObjectType? (using RhinoObject or ObjRef as input)?
I don`t see anything in the Attributes…I could check for every possible type:
var curve = gc.Object(i).Curve();
if (null != curve)
I guess I have a curve
But that seems a bit much…?
Thanks!
RhinoObject has an ObjectType property that reveals objects ObjectType enum. If you’re prompting the user to pick some objects its often less effort to setup a geometry filter on the GetObject so that you can easier filter and inspect the results.
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_DocObjects_RhinoObject_ObjectType.htm
Hi @dimcic
The as keyword is very useful.
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsCommands/SampleCsClassifyCurve.cs
– Dale
