Rhinoceros Script Compiler
Compiler sends error since 2 weeks. (Rhino 7.2)
ErrorMessage:
The compiler generated the following errors:
Exception:ArgumentNullException
Message:Der Wert darf nicht NULL sein.
Parametername: stream
Any ideas?
Thanks
Hello - I don’t know if it is the same bug but there was a fix about 3 weeks or so ago in 7.3 - if you can change Options > Updates and Statistics page > Update frequency to “Service Release Candidate” you can get 7.3 and see if that has fixed the bug you see.
Thank you very much,
Problem is solved with 7.3
