Just installed Rhino Work In Progress
(7.0.20210.12505, 28.07.2020) and can not manage to make a regular solid cylinder. Am i missing a setting?
That looks right for a subD cylinder. Either add some holding loops at the top and bottom or crease the top and bottom edge loops
Set the CapFaceStyle = Tri in the command line options.
Run the Crease command on the edges that border the cap.
Hi -
If the answer by Trav isn’t what you were looking for, perhaps you are trying to figure out how to work with the non-smooth version of SubD objects in Rhino? If so, use the SubDDisplayToggle
command - which, by default, is assigned to the Tab key.
