Running a command through RhinoApp.RunScript method:
for instance RhinoApp.RunScript(! _Circle,true)
stores the command in the recent command list (command prompt -> right click) but if the command has parameters
for instance RhinoApp.RunScript(! _Circle _3Point,true) it doesn`t appears, and if you click with right button on the viewport to repeat the command it doesn’t work.
Is there something wrong with that, or I need to do any thing else.
