Rhino9 bug? inch dec vs inch fractional
Working in Win11, Rhino9 beta. I have an inch decimal annotation shown here
I changed it to inch fractional and instead of a fraction like 3 3/4", I get
Rhino 9 SR0 2026-8-11 (Rhino 9 BETA, 9.0.26223.12303, Git hash:master @ 535bf21f011dc805eafa540606c59272f4f15b11)
License type: Commercial, build 2026-08-11
License details: Cloud Zoo
Expires on: 2026-09-25
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 1-20-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port 0
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-11-2024 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
  • There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Hi @Joe4,
I do see the issue.
Inch Fractional has its model unit format set to Model units - decimal.
This is a bug. RH-97774/Annotation-Styles-in-Templates-Assigned-Incorrect-Model-Unit
It is private now, but the developer may open it next week after it is reviewed.
It is likely a template issue.
Workaround: Change the Annotation style to use the Length Unit of Inch Fractional.
It should be set to Inch - fractional.
Assign your dimension to this style in Properties → Dimension page.
If you do this, then the dimension will look correct.
See the attached file where the annotation style has been fixed.
Decilmal and Fraction.3dm (44.6 KB)
We will let you know here, when there is a fix to test.
Thank you!
Mary Ann Fugier
Thanks for the work around. Will look forward to a fix.
Joe
