The isocurve is not visible on the end cap plane of a cylinder or on a single plane surface. Can I make it visible? Because it is not visible, it is very inconvenient to get your bearings.
Hi -
Yes, check the Show for flat faces
option in your display mode settings:
thank you I didn’t turn off any settings after installing Rhino 8, which is strange. Anyway, thank you very much. Thanks to you, it was easily resolved.
McNeel has a policy of setting new display and similar “features” as default when new versions are released. It’s a way of making sure users are aware of the new features, but also confuses many, many users when the new version of Rhino does not function as expected.
