Rhino8 not responding and crashing. Nvidia Geforce RTX 2050
Rhino8 is not responding and crashing on new gamers laptop, when using a not so large 3D model.
The video card is Nvidia Geforce RTX 2050. Laptop HP Victus.
Any special settings I should use to avoid the ‘not responding’ freeze?
Here’s the ‘Command: SystemInfo’:
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Evaluation, build 2024-02-13
License details: Cloud Zoo
Expires on: 2024-04-27
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-15-2024 (M-D-Y).
> Integrated accelerated graphics device with 5 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 2050 (NVidia) Memory: 4GB, Driver date: 8-14-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.13
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2023
Driver Version: 31.0.15.3713
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
And from NVIDIA control centre:
Thanks in advance for any suggestions.
I guess the first thing I would try is updating the NVidia driver to the latest and see if that helps…
Also, it would be good to already update to service release candidate for Rhino 8.5 through Tools > Options > Update and Statistics. Set update frequency to Service Release Candidate.
Ok, just updated it to latest 8.5
you still need to ensure you are on the latest available Nvidia driver if you haven’t already.
When you do update make sure you go through custom/advanced install and check clean installation.
Ok I had it updated doing this in Device Manager:
Would you know if that’s enough, or shall I download NVIDIA software GEFORCE Experience?
Don’t use the device manager to update. Instead download from the vendor. This is the latest for your GPU:
Great thanks, I updated it, and it seems to work better already.
