Rhino8 isolate text with horizontal view will ignore the other text
It is a little bit hard to say…
For example, I group one text and a box for “test_01”, and one text and a cylinder for “test_02”, and one text and a sphere for “test_03”. I select the group with the “test_01”, and then i change the view angle to a horizontal view, where the text will be disappeared, meanwhile I click the button “isolate object”, and change the view angle to normal, you will see the text “test_02” and “test_03” and the object box, when I re-select the box you can see I have also select the text “test_01”…
here are the pictures with this bug…
BTW, this problem is not in the Rhino7… how can i solve this…
Hi -
RH-81360 Invert / Isolate doesn’t work on annotation objects perpendicular to view
This issue is fixed in 8.7, a first public release candidate of which is planned to be released tomorrow.
Thanks, so efficient!!!
