hi @seghierkhaled @wim @DavidRutten @Gijs
A plugin that should be displayed in the Rhino8(grasshopper) toolbar will not be loaded and will not run if loaded
i think this is bug in)(grasshopper) Rhino8
the plugin name is:
Yes, it won’t load for me in Rhino8
My settings are:
What are your settings?
and Persistent Data Editor and Quick Connectionloade and work for YOU?
Rhino8 load ExtaButtons package from Rhino7 folder, i don’t install it twice
No Persistent Data Editor don’t loaded , i think it need a new SDK
@seghierkhaled Thanks for reply,
And when i removed SuperHelper plugin then extrabuttons bottom and melanoplus work for me fine in Rhino8,
But:
PersistentDataEditor and [QuickConnection]
are opensource in github
I change Sdk nuget.org packeges grasshopper v8.1 to Rhino8 in Visualstudio
and rebuild it
But doesn’t work stil!
Do you have any suggestions? Or help because this plugin is very useful and the author won’t answer to fix it! Maybe there is a bug in the Rhino8 sdk?
In food4rhino the plugin already support Rhino8
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\8.0 >> PersistentDataEditor
Yes! PersistentDataEditor But it doesn’t run as well as Rhino7 for components
And quick-connection doesn’t loaded
Create a shortcut of Rhino8 and call it for example Rhino 8 net
Right click and open properties window
add space + /netfx
in the Target like this:
“C:\Program Files\Rhino 8\System\Rhino.exe” /netfx
You can then use all non supported plugins, if you can’t use a plugin you need to ask the developer
exactly! thanks very much by this method resolved and PersistentDataEditor and quick-connection worked fine
*So should mcneel developers fix NETFramework bug? In Rhino 8 To loade Grasshopper Plugins?
@Gijs @wim
The solution from here
It is not a bug , but all plugins in future must updated to net7
Both projects are only built to support net framework 4.8:
If you want to support both net48 and net7.0, you should look at how to set up multiple target frameworks:
Essentially:
<TargetFramework>net48</TargetFramework>
to
<TargetFramework>net48;net7.0</TargetFramework>
Thanks
@fraguada i trying to add net7 to this plugins like your suggestion but created error in Visualstudio
And (sdk Rhino8 doesn’t install on too)
Please share the error.
Hi @fraguada
i change this Line:
<TargetFrameworks>net48;net7.0</TargetFrameworks>
<Version>1.1.4</Version>
<Title>ComponentToolkit</Title>
first open not error but when Rebuild
Error:
Severity Code Description Project File Line Suppression State
Error NETSDK1136 The target platform must be set to Windows (usually by including '-windows' in the TargetFramework property) when using Windows Forms or WPF, or referencing projects or packages that do so. PersistentDataEditor C:\Program Files\dotnet\sdk\7.0.400\Sdks\Microsoft.NET.Sdk\targets\Microsoft.NET.Sdk.DefaultItems.targets 146
and i try to install grasshopper.8.1.23318.13001-rc.nupkg in net7 folder but error not fix
grasshopper.8.1.23318.13001-rc.zip (3.2 MB)
