Rhino8 crash
I cannot open rhino8 at all, it crashes instantly.
It is installed on a virtual box on Monterey Mac OS 12.6.1.
ranslated Report (Full Report Below)
Process:               Rhinoceros [1362]
Path:                  /Applications/Rhino 8.app/Contents/MacOS/Rhinoceros
Identifier:            com.mcneel.rhinoceros.8
Version:               8.6 (8.6.24101.05002)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2024-04-17 16:50:48.1849 -0700
OS Version:            macOS 12.6.1 (21G217)
Report Version:        12
Anonymous UUID:        39FE1411-A309-449D-8041-D3094136320C
Time Awake Since Boot: 830 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.Metal.DeviceArray
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x00000001f74e0fd8
Exception Codes:       0x0000000000000002, 0x00000001f74e0fd8
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 10 Bus error: 10
Terminating Process:   exc handler [1362]
VM Region Info: 0x1f74e0fd8 is in 0x1f74e0000-0x1f74e1000;  bytes after start: 4056  bytes before end: 39
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      __LINKEDIT                  1f74d8000-1f74e0000    [   32K] r--/rwx SM=COW  ...viderOverride
--->  VM_ALLOCATE                 1f74e0000-1f74e1000    [    4K] ---/rwx SM=NUL
      VM_ALLOCATE                 1f74e1000-1f74e8000    [   28K] rw-/rwx SM=ZER
Application Specific Information:
abort() called
Thread 0 Crashed::  Dispatch queue: com.Metal.DeviceArray
0   libunwind.dylib               	    0x7ff81b4c7dfc libunwind::UnwindCursor<libunwind::LocalAddressSpace, libunwind::Registers_x86_64>::step() + 388
1   libcoreclr.dylib              	       0x146ada592 PAL_VirtualUnwind + 386
2   libcoreclr.dylib              	       0x146bef89b Thread::VirtualUnwindToFirstManagedCallFrame(_CONTEXT*) + 107
3   libcoreclr.dylib              	       0x146d3dea5 HandleHardwareException(PAL_SEHException*) + 533
4   libcoreclr.dylib              	       0x146ada0bb SEHProcessException(PAL_SEHException*) + 315
5   libcoreclr.dylib              	       0x146b1346b PAL_DispatchException + 139
6   libcoreclr.dylib              	       0x146b130f3 PAL_DispatchExceptionWrapper + 10
7   libcoreclr.dylib              	       0x146b84064 HashMap::LookupValue(unsigned long, unsigned long) + 4
8   libcoreclr.dylib              	       0x146b84064 HashMap::LookupValue(unsigned long, unsigned long) + 4
9   libcoreclr.dylib              	       0x146b84064 HashMap::LookupValue(unsigned long, unsigned long) + 4
10  libcoreclr.dylib              	       0x146b84064 HashMap::Lo
This could very well be the problem - we can’t support Rhino running in these environments.
Can you run Rhino on a non-virtual box?
— Dale
Sadly no. Installing already a working virtual environment of mac is also tricky… any experience to share would be much appreciated… I have ubuntu and need to compile C++ library for Mac Rhino. Dont have a pc with Mac. I found a Monterey version 12.6 that Rhino supports, but Rhino has infinite crash after installation…
