Rhino8.2 - Exporting to PDF results in blank page for rendered details
I downloaded the 8.2 update for rhino yesterday and I’m now having issues exporting to PDF.
I use rendered or arctic display modes a lot for my details when I’m drafting and now every time I try and export to a PDF they result in blank pages or only showing the top left corner.
Exporting to PDF with wireframe / shaded mode works fine.
When I go to export the print preview looks as it should too.
I’ve tried shutting it down, restarting my computer, only having 1 detail on a page and nothings working.
Please help!! Thanks
Hi @natashabw thanks for the report. I have created a ticket to investigate the issue. You can follow its progress form this link. RH-79093
Hi @natashabw,
Would you be able to provide a model with this problem? I tried reproducing it but it seems to work fine for me.
Also, I’d like to know if you can still see this issue in Rhino 8.3. There’s a chance this was fixed in 8.3.
It seems to be working again at the moment! So hopefully the update’s fixed it, thank you!
Hi, sadly it’s still not working for me.
Downloaded the 8.3 update
Realised the problem lies not with the rendered display mode that exports fine with skylight turned on. It’s when I turn the skylight off to have shadows then it doesn’t export the layout to pdf.
I’ve done a basic test model as can’t share what I’m working on at the moment and it still doesn’t work with this basic model:
Cart 2158.3dm (4.2 MB)
But exports fine when skylight is turned on: (exactly the same print settings)
@natashabw Thanks for the model and the screen shots! I have made some tests:
  • Rhino 8.2: I can reproduce the bug.
  • Rhino 8.3: I can reproduce the bug.
  • Rhino 8.4: The bug seems to have been fixed in this version.
If I’ve understood things correctly, I believe Rhino 8.4 will be available as a Release Candidate in about 7 days. Test it out then and let me know if you see the same as I do.
-David
Im still getting this bug on details that are set to rendered. I am currently using Rhino 8.7 for mac. I tried both print to rhino PDF and Export. Both seem to bring up the same options box. I also tried printing it and it came out as wire framed instead of rendered.
Screenshot of layout in rhino:
Screenshot of exported PDF:
System info:
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15432, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Commercial, build 2024-05-17
License details: Cloud Zoo
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 32GB)
Mac Model Identifier: iMac20,1
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon Pro 5300 (4 GB)
iMac (2560 x 1440)
USB devices
Logitech: USB Receiver
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.7.24138.15432
Hi Tilly -
Please post or upload the 3dm file so that we can attempt troubleshooting this.
346_JU05 High Tables_R2.3dm (7.1 MB)
After working for a while the bug is back!
Can’t export to pdf in rendered mode with skylight off.
Downloaded the most recent update, but not working.
Exactly the same problem as before, attached the test model again.
Any help would be appreciated thank you!
Cart 2158.3dm (3.9 MB)
Just wondering if this could be logged as an issue,
Thanks!
It’s also not working in view capture to file either, it exports a section of the top left and not the rest of the image
This should all be working in the latest build of the day (BOTD) on Windows. I’m still looking into why some scenarios don’t work on the Mac.
-J
Hi Jeff,
Is there a solution to this issue yet?
I’ve downloaded the latest update and now any rendered or arctic view won’t export to PDF even with skylight turned on which is really frustrating!
Please help! I have deadlines coming up and need to be able to export pdfs easily.
Thank you!
Attached views and an example model for reference
Test.3dm (2.8 MB)
Hi Natasha -
I’m seeing this in a current version of Rhino 8.12 but it looks like this is fixed in Rhino 8.13. I’ll send you a link so you can try that out.
Correct… This was fixed a little over a week ago in 8.x (8.13).
Please let me know if it’s still not working with the version @wim provides you.
Thanks,
-Jeff
Yes, it’s all working in Rhino 8.13.
Thank you both!
