We use jump lists in Windows 10 to access recent and pinned files a lot - basically all of the time as it’s just so efficient to do so - but since upgrading to Rhino 7 it’s takes several minutes to launch files this way, so we can’t practically use this functionality.
Any ideas?
Launching files directly from file folder seems to be fine.
It appears to be happening on at least one other system that I know of for sure, but believe there are a couple of others. We are all working remotely at the moment, so we are not necessarily using our workstations, or have them accessible to check.
Effectively, if I right click the R7 toolbar, a list of recent files populates in the jump list. Whether I left click on the file I want (selecting it normally), or right-click on the file and select open with Rhino 7, I will have no response from Rhino for several minutes.
Sorry, I am unable to give you any more information, as we don’t know! All other programs, including R5 and R6 also work fine.
As a side note – another weird issue I am experiencing, is that when I have Rhino 7 open, the Windows task bar indicates (by the light blue line) that the file open is a Rhino 6, when this is not the case! Underlined in green below.
I’m afraid that doesn’t really matter. There a lots of differences in the Rhino 7 version and “not supported” only means that it might or might not work - not that it definitely doesn’t work.
Is there any way you can test the same thing without a remote desktop?
Whilst we are all currently working remotely with many using Remote Desktop (although some have their workstations set up at home), we’ve had the same issue in the office not connecting remotely. Unless is your proposal to remove the RD installation?
